420c Final drive
Josh
01-17-2004 11:36:14
I found a casting # on the final drive of my jd 420c.(M3687T) Does anyone know if this is the stronger final drive? If this is not enought information, could someone describe the visual diffrences between the two drives? Thank you -Josh
Lavoy
01-18-2004 10:09:58
 Re: 420c Final drive in reply to Josh, 01-17-2004 11:36:14
Look at your final case and see if it has 4 large ribs cast into it that go from the edges of the case toward the axle. If so, you have one of the heavier final drives. If not, you have the earlier final that was used on 40's after 62,264, and on 420's before 100,000. The ribbed case became the sub number for the 40 and early 420's after it was developed for the phase two 420's, then the earlier case was discontinued. None of the finals would likely break under normal useage, it is usually abuse and lack of maintenance that caused them to fail. If you rebuild your finals correctly, and maintain them, it is unlikely that you will have any trouble. Lavoy
ED
01-17-2004 15:38:22
Josh, I am in northeast and have new and used parts for these machines here is my link to my site Link
ralph
01-17-2004 12:16:30
that is the right one for a 420-430--i don't know what you mean by stronger one the 40C one will fit but not te right one. ralph
Josh
01-17-2004 12:37:26
 Re: Re: 420c Final drive in reply to ralph, 01-17-2004 12:16:30
I was under the impression that the final drive was redesigned after serial # 100001 because it would not hold up under normal working conditions. Where did you find the casting info? Thank you -Josh
ralph
01-17-2004 13:28:27
 Re: Re: Re: 420c Final drive in reply to Josh, 01-17-2004 12:37:26
all 420's the same no # brake by the parts book plus been wrecking out these for 30 yr's ton's of parts. where dp you live? ralph
Josh
01-17-2004 13:54:18
 Re: Re: Re: Re: 420c Final drive in reply to ralph, 01-17-2004 13:28:27
Maine, I don't think need the final drive yet (I hope). but I'm going to dig into it next week I'm sure I'll find many things wrong. The engine base is full of watter (frozen) not sure if there will be any problems. if you have parts for sale let me know how to get in contact with you, chances are you'll here from me. where are you located?? Thanks -Josh
ralph
01-17-2004 14:01:52
 Re: Re: Re: Re: Re: 420c Final drive in reply to Josh, 01-17-2004 13:54:18
i live in oregon. ralph
Looking for Help
01-17-2004 19:09:17
 Re: Re: Re: Re: Re: Re: 420c Final drive in reply to ralph, 01-17-2004 14:01:52
Ralph: Do you have parts for other brands too?
ED
01-18-2004 02:56:44
 Re: Re: Re: Re: Re: Re: Re: 420c Final drive in reply to Looking for Help, 01-17-2004 19:09:17
I have parts for all kinds new and used Link
ralph
01-17-2004 21:34:01
no just deere but what do you need maybe i can help. ralph
