snow chains for case backhoe
Gary
01-19-2004 10:48:46
Have a 580c Case backhoe. Went to put chains on it and they will rub the fender brace. Does anyone know if they make a spacer for the rear rims to move them out some. Gary
Rich
01-19-2004 19:20:08
 Re: snow chains for case backhoe in reply to Gary, 01-19-2004 10:48:46
Gary you can get spacers. You can't afford 'em. Watch your yard sales next spring. Buy 3 sets of auto tire chains a buck a pair. You need to split the outer chain off one side of all six chain pieces. Get a pile of repair links. Tie the two pieces into a single ladder. Now you have three ladders that will fit a 16.9 tire. Cut one in half. Connect a half to each of the two remaining ladders. Now you have a pair of chains that will fit your Tractor and won't rub the hydraulic lines under the fender. You'll need 6 18" bungies for stretchers. If you work much on paved surfaces you'll need to keep some repair links in your tool box, particularly if you have good tires. You'll find the tractor is ferocious in the snow and ice with the differtial locked. Good luck.
