JD 450-B Brake/Clutch wont work
Darryl
01-19-2004 19:38:06
I have a 450-b that I have had to adjust the brakes on several times since I have owned the last year. Now when I pull the lever back for the right side it makes the crawler stop like both brakes are on. A friend who has adjusted the brakes said there seemed to be oil (something wet) in where the brakes are adjusted on one side. Dont know if this is the or a problem? Any advice would be appreciated.
ED
01-20-2004 01:04:48
 Re: JD 450-B Brake/Clutch wont work in reply to Darryl, 01-19-2004 19:38:06
sounds like left side is not driving will need steering clutches rebuild If you need parts i have them also input seal may be leaking ED Link
