CAT 931 Sprocket
JimInOz
01-20-2004 05:06:07
Hi guys.I need to remove a sprocket from a 1974 931 loader.Any ideas on removal at home,or do I need to take it to a workshop?Thanks again.
Bob/Ont
01-20-2004 05:24:02
 Re: CAT 931 Sprocket in reply to JimInOz, 01-20-2004 05:06:07
You need a hyd press to get them off and back on tight enough Jim. It will be cheaper to pay to have them pulled and pressed back on rigth than have one come loose and ruin the tapered splines. Are you doing undercarrahe or just a final drive seal? Later Bob
JimInOz
01-20-2004 12:30:51
 Re: Re: CAT 931 Sprocket in reply to Bob/Ont, 01-20-2004 05:24:02
Hi BOB.I'm actually wrecking the 931...it's down to being just a big oblong block,which is the rear end.I just need to get the sprockets off to get into finals/steering,etc.Thanx Bob,I enjoy your posts.
Bob/Ont
01-20-2004 13:27:27
 Re: Re: Re: CAT 931 Sprocket in reply to JimInOz, 01-20-2004 12:30:51
Jim, you can just unbolt the cases from the steering clutch case and sell them sprockets and all assembled. You will need a puller to get the flanges off the final drive pinions and the bevel gear shaft though. Later Bob
