D2 Cat- Pony Motor clutch
Darryl
01-21-2004 13:16:17
I have a D2 cat and I can't get the clutch on the pony motor to release so I can start it. Any ideas?
Doug in IL.
01-22-2004 08:24:09
 Re: D2 Cat- Pony Motor clutch in reply to Darryl, 01-21-2004 13:16:17
Darryl, I have a D7 this used to happen with. There is a cover on the side of the pony clutch housing with 4 bolts in it. Take this cover off. You will see the toggles for the clutch engagement. Just pry one of them back with a small prybar or heavy screw driver. Your clutch may be adjusted too tight. I have a D2 also, but it is not home right now. So I can't look at it to see if it is like the D7.
Darryl
01-22-2004 09:08:40
 Re: Re: D2 Cat- Pony Motor clutch in reply to Doug in IL., 01-22-2004 08:24:09
Thanks. It worked .
