TD-6 NEEDS HELP
Carol
01-22-2004 06:54:49
I just got a old TD-6 crawler,but the engine has a miss and has some oil comeing out the exhaust when running. Any ideas?Stuck ring? Its been siting along time but the head was rebuilt. Thanks
swedeguyTD9
02-20-2004 13:25:45
 Re: TD-6 NEEDS HELP in reply to Carol, 01-22-2004 06:54:49
I had the same problem at my TD9, what I did was to adjust the valves. Runs fine after that. /Dennis
Ray weideman
01-25-2004 18:26:40
Just found miss. Idler gear wasn`t put on right n was loose. The cam gear is more common to be loose N cause a miss. Put a 15/16 on end of tmeing of injection pump. If it move`s 3/16 or more the cam gear is loose. Locktight should do it. Would like to find out the year on mine from serial no. If u know where to look let me know. Thank`s. Engine that is. I think engine was changed.
Ray Weideman
01-26-2004 06:27:50
 Re: Re: TD-6 NEEDS HELP in reply to Ray weideman, 01-25-2004 18:26:40
The eng. no. is D264 - 5473. Would like to know what year that is.
clark
01-23-2004 07:02:46
I just got done restoring a TD-6 last spring. i did the engine and everything else on the machine. when i bought the machine it also missed really bad. blew blue smoke and unburnt fuel out the exhaust. i applied air preasure into the cylinders through the spark plug holes. I made a adapter. preasureised each cylinder. I soon could hear bubbleing in the radiator. this ment a blown head gasket or cracked head. unfortuneatley mine had a cracked head infact severial cracks. the head was beyond repair so i found a head and had it rebuilt. total cost for just te head was 1700 bucks. then it was on through the resto fo the engine.$$$$$
Carol
01-23-2004 17:10:06
 Re: Re: TD-6 NEEDS HELP in reply to clark, 01-23-2004 07:02:46
Thanks Clark,I hope its just the injectors. This Td was made in Canada I thing.S/n 18501TCDM Have no idea of the year.
Ray weideman
01-26-2004 06:36:17
 Re: Re: Re: TD-6 NEEDS HELP in reply to Carol, 01-23-2004 17:10:06
It`s a 1949 I think by my book. Ray
gm
01-23-2004 21:05:54
If it turns out to be a cracked head, I have a used head with injectors for $450. -Greg
king of obsolete
01-23-2004 17:37:37
they were talkingabout serial numbers at redpower the other night, i think it might a very early 1940's, thanks
king of obsolete
01-22-2004 07:36:38
come over to red power, lots of pictures too, ----- Link ----- -thanks
