Is an International 500E a decent dozer?
RT (SE TX)
01-22-2004 10:04:06
I have a chance to buy a 500E. Only one track is currently pulling. Are they any good? Reliable? What's the likely cause of the non-pulling track and are parts available to repair? What engine do they have? Thanks in advance for your replies.
Rick from Paso
01-22-2004 22:14:16
 Re: Is an International 500E a decent dozer? in reply to RT (SE TX), 01-22-2004 10:04:06
I have a 500C and it is my best work horse. Mine has a torque converter and a reverser. These are in my opinion the weak points of these tractors. I have read more problems with the trannys on these, leaking seals, torque converters and reverser valves. The reversers are very handy, but lend themselves to abuse. Mine have functioning problems from time to time where you go to change directions and it has no power. My problem might be steering brakes hanging up but I have read several posts where people have had similar problems. Do a search for 500 on this forum. Also parts are very hard to come by and are very pricey if you can find them. When they work correctly, they are wonderful tractors. I use it for everything, building barns, moving sand, dirt, telephone poles, hay bales, digging, light dozing and so on. It's the best money I have spent, but I don't use it hard.
Steve
01-22-2004 14:23:37
third party image
We have new steering discs available as well as many other parts such as final drive gears, etc.
ED
01-22-2004 12:53:02
RT The non pulling track could be steering cluches they are a dry clutch machine. They are a good machine some parts are just starting to get hard to get The engine is 155 3clyinder 44hp and the machine wieghts 10,700 If you need parts i may be able to help you Link
