back-hoe thumb
Joel D. Taylor
01-23-2004 12:47:44
Does anyone have experience installing a mechanical thumb on a Case 580D standard hoe. Are there any suppliers that are better than others? Is it safe to weld on the dipper tube? Any advice is appreciated. Thanks in advance.
Taylor Lambert
01-23-2004 18:44:33
 Re: back-hoe thumb in reply to Joel D. Taylor Jr., 01-23-2004 12:47:44
I agree with Marlowe on the clamp on thumb. O made one the other day for a fella that the bucket pin also held the thumb. and the leg later cylinder was clamped to it. the dipper sticks on most Case hoes are Ductile Iron and thats not good to weld on. Marlowe what part of the country are you located?
marlowe
01-23-2004 19:30:57
 Re: Re: back-hoe thumb in reply to Taylor Lambert, 01-23-2004 18:44:33
central WI.
marlowe
01-23-2004 17:31:59
i made one for mine and i put a clamp around the tube so i can slide it up or down 4 3/4 in. bolts with 1/2 in. flat steel on each side of tube
