d6b clutch stuck
i r baboon
01-23-2004 17:17:06
dont have book on it, do they have hyd cyl operating steering clutch? brake works fine, strng clutch wont release. be blessed
for bob/ont
01-24-2004 14:43:16
 Re: d6b clutch stuck in reply to i r baboon, 01-23-2004 17:17:06
thanx, r clutch wont release. seller thought hyd cyl above rear end needed service? just got her, d6b 37a 1894, what yr? am me;chanical, have shop bldg. is elec start, hyd blade. did they make a pto for her? thanks for larnin me, nik in tx jan_o2000@yahoo.com
Bob/Ont
01-25-2004 19:03:13
 Re: Re: d6b clutch stuck in reply to for bob/ont, 01-24-2004 14:43:16
Here is how it works. The steering booster in under the seat and there is a pipe with a plug on top to fill with oil. The booster has a pump under it and it is driven by the trans input shaft. When you have the engine running and the master clutch engaged. Traveling or in neutral the pump is working. When you pull back on the steering levers you should feel resistance then the booster will kick in and the lever goes back all the way freely. Is this happening? You say the RH doesn't work. Do the RH and LH both feel the same when you pull back on them? Make sure the booster is full of oil, try them one at a time and both together and get back to me with how they are responding. Later Bob
Bob/Ont
01-23-2004 18:41:37
Baboon, look in the holes under the covers on the back and see what is going on inside. Will one or both not release? They have a booster on the top of the case. What is the serial#? Later Bob
dan pendzick
02-17-2005 14:08:56
 Re: Re: d6b clutch stuck in reply to Bob/Ont, 01-23-2004 18:41:37
looking to buy a d6b--serial 44a--machine will not turn to the right, it appears that right clutch will not release--how much of a job to pull steering clutch--steers well to the left.
