is a JD450 big enough?
Rich
01-23-2004 22:34:45
i am clearing a wooded area for a house. Is a JD450 dozer enough machine for this job? The trees are mostly 10 in. dia pines. Thanks
Dozerboy 450
02-15-2004 05:30:38
 Re: is a JD450 big enough? in reply to Rich, 01-23-2004 22:34:45
I have an old plain 450 and I am very happy with it. I bought the machine to do the same thing to thistle trees. I never run out of power, just traction. I must say though that I am not using it to down anything that big. I need new cleats, so I can't take on anything too big . . . yet :) One thing that may be obvious is to down them when the ground is wet and not frozen. It make a mess but you'd be amazed by how much easier they fall when its wet out. If you get one, watch out for steering problems, I understand they are common if not used and can be expensive to fix. Mine steers ok now and I plan to go out and use it at least once a month to keep it that way.
Chris
01-27-2004 09:54:07
Just a suggestion..I'm not familar with JD...but getting a loader might be more useful...It makes it easier to push down trees and move them around..I was going through the same thing ended up with a CAT 955H..man o live those trees push over easy...roots and all. I must agree get ROPS it has already saved my butt.
RexB
01-25-2004 19:50:47
Yes, did it with my 350 (dry clutches!) just dandy, dug around the trees bigger than 10", ROPS saved my arse. A 450 would have been sweeter.
Billy NY
01-25-2004 15:13:55
I'd say you'd probably be ok, we had a 450 a long time ago, take your time, use caution, make sure you have good solid overhead protection, brush cage etc., can be dangerous work and falling limbs / trees show no mercy.
JD dozer mike
01-25-2004 09:16:43
450 should be , I clear land like that with my smaller 440 , It's a lil slow but does the job.
jdemaris
01-24-2004 06:22:53
Yes, it's a powerful machine for its size. It will push circles around a 350.
David in SC
01-24-2004 02:41:55
See my post below, "Near miss tonight". I was very surprised at the power of a JD 450C. Unfortunately, the way I saw it was when one got out of control and shoved a Ford F450 around a little. Be careful. David
