TD14A starting
Dennis
01-25-2004 16:11:08
I have this opportunity to pick up a free TD14A that has been sitting for 14 years. The Tarp that covered it is all rotted out. I put the crank in and turned over the engine. How do I start up this thing. It has two 12 v Batteries under the seat which I will replace. Clean out the gas, check the carb, check the plugs, drain diesel and flush well. Now What?? How do I try to start this up. Is there a manual I can buy? Recommendations will be appreciated
JerePa
01-26-2004 17:15:11
 Re: TD14A starting in reply to Dennis, 01-25-2004 16:11:08
By all means, get manuals for it. Instruction & parts. This site would have them or binder books. First thing (after you get all the regular stuff done) & check if all the valves are moving (closing) (valve cover off) is get it running on gas. Let it get hot. If all the diesel lines are bled out (only fresh fuel oil will do), See if it will run on diesel by throwing the lever (inst. man. will show you the way. If all you get is smoke (white) let it run awhile to see if the smoke goes away. If not, the rings are either bad or stuck.
king of obsolete
01-26-2004 20:16:01
 Re: Re: TD14A starting in reply to JerePa, 01-26-2004 17:15:11
also i'm finding out that if your fuel plungers are not up to par, then the injectors willnot open, i got a td-18 that will run on gas but dies on diesel, the boys at redpower have been helping me with picture and phone call too, thanks and best of luck
Brian
01-25-2004 21:49:02
Check out red power forum bunch of IH crawler boys there
old
01-25-2004 17:38:27
Yes theres a manaul for them I'd try to explain how to start it but I'd fill this page up plus, theres a couple levers that have to be just right to start it on gas then when its warm you switch it over to diesel and then when you shut it down you should switch back to gas first. I had a TD6 which is just a smaller one then what you have good machines but
jim/pa
01-26-2004 15:03:22
 Re: Re: TD14A starting in reply to old, 01-25-2004 17:38:27
about 5 yrs ago i rescued a machine in almost the identical shape as yours. its a td-14, gas start diesel. like the other reply, it'd take a whole page to explain. if you'd like to call me, i can give ya a pretty good rundown. email me, and i'll give you my number and we can work out a time to call if you'd like. jim
