fuel consumption.
rich
01-25-2004 17:38:51
JD 450 dozer...clearing trees....32 gal fuel tank...anyone have a clue about how often i will need to refuel? I am working in a very remote area. Thanks
rich
01-26-2004 19:08:00
 Re: fuel consumption. in reply to rich, 01-25-2004 17:38:51
You guys are great...glad i found this board. First day went great, thanks to your help. 6 days work to go.
Mark
01-26-2004 18:15:59
Rich, I can go a full day on my 450C loader and still have plenty left. However, I like to keep it full as much as possible because it keeps the moisture down inside the tank. Watch your RPM's and that will help your fuel consumption. Don't lug it, but no need to over-rev it and produce high RPM's that you don't need. Good luck.
Dave Grubb
01-26-2004 16:41:56
The book says 1.5 to 2.3 gallons/hour as typical. Most construction equipment is designed to go at least 10-12 hours without refueling.
Mike
01-26-2004 09:32:56
If you are using it at its maximum potential, 3 gallons an hour.Figure on filling it the end of a 10 hour day.
RexB
01-25-2004 19:42:20
My JD350 recently used about 12 gal in 28 hours of clearing and road levelling work at 2700rpm, if i remember the number of fuel cans right. Its 3 cyl diesel just a little less fuel hungry than 450.
