How hard to replace rear engine oil seal on TD6?
Rick from Paso
01-29-2004 21:55:45
I have a lot of oil in the bottom of the clutch compartment, looks like a bad rear engine oil seal. Do I have to pull the motor to replace this? I have a set of manuals but they don't specify how this is to be done. Thanks for your help.
Clark
01-30-2004 10:14:42
 Re: How hard to replace rear engine oil seal on TD in reply to Rick from Paso, 01-29-2004 21:55:45
the engine doesnt necessarely have to be remove to replace the seal. but all that you have to go through to do it with the engine inplace is harder than removeing the engine. It is a quite large 2 piece seal. It cannot be fished into place. the oilpan needs to be removed. and the clutch & flywheel also.keep inmind that the engine weighs around 3500lbs and requires a good lift to hold it.
goofus fr L.A.
01-30-2004 09:30:59
Rick, I have known of the seals being pulled in place with a wire. You have to be able to remove the oil pan first. Most tractors seem to have some kind of obstruction. Sounds like a good mother n law job, to pull the engine. Keep her out of the house for a while. goof
king of obsolete
01-30-2004 05:22:33
they just decussed this at redpower and the fellows talked about part numbers too, do a sreach on td-6 and you will find with pictures thanks----- -http://redpowermagazine.com/cgi/yabb/YaBB.cgi?board=news ----- -thanks
