td 7e hard to start when temp below 35 deg
ajc
02-06-2004 21:56:54
I have a td7 e 1984 model has either aid on starting. when temps get around 30 still hard to start i know block heater would help out alot but were it is used just no were to plug it in is there any sugestions and even in the summer it wont start unless you give it a shot of either.and i have been told either is pretty hard on a diesel motor.
Ray
02-09-2004 09:04:14
 Re: td 7e hard to start when temp below 35 deg in reply to ajc , 02-06-2004 21:56:54
On other discussion boards I've heard of using WD-40 and propane as starting aids, either which are supposed to be easier on engines than ether. Some said that a "new" formulation of WD-40 doesn't work, but when I lit the spray from a new can, it burns great. Supposedly, new diesels have propane injection, which sounds like a good alternative. Using a little bit of any of them seems prudent. There are stories of ether causing serious damage (bent rods, etc.) as well as erosion of rings, etc. A whiff of ether may do no damage, but excess is definitely bad news.
Jim
02-07-2004 10:17:06
you should have a place onthe throttle for cold start - it advances the timing in the injcetior pump. If it is not working you have problems in the injcetion pump and need to pull it to have repaired.
