440 dozer
tom morstorf
02-07-2004 11:42:10
Want to know if anyone would know what the cost would be to fix the steering clutches on a John Deere 440 dozer. It is about a 1960 model. Also where could I get the parts to fix it? If this dozer cost $2,500 would this be in the ball park price?
Karen
02-08-2004 03:48:03
 Re: 440 dozer in reply to tom morstorf, 02-07-2004 11:42:10
If you email me I know a place where you can get the parts cheaper than prices already discussed
ralph
02-08-2004 12:03:24
 Re: Re: 440 dozer in reply to Karen, 02-08-2004 03:48:03
i would also like to know where to get cheaper parts. thanks ralph
Lavoy
02-07-2004 20:33:35
Tom, I have all the individual parts for the steering clutches for sale. I also have kits that will do a complete clutch with all the discs, pressure plate, brake band, throwout bearing, springs, and a gauge for setting the pressure plate. I also have bearing kits that include all of the bearings and seals for the final drives. Lavoy
JD dozer mike
02-07-2004 17:37:41
I redid mine , got the parts from JD , Provided the pressure plates are ok. the metal discs are 25$ ea (depending on your model number) you will need 7or8 on each side , the fiber discs are also about 23$ and will need 6-7 on each side , May as well change throw bearing while you are in there 30$ EA , if brakes need doing they are 250$ from JD for REferbs. or you can get relined if you can find a place for about 100 EA. While i was in mine i changed the final bearings and seals and gaskets ,, all in all it ran around 1,200$ to do it all, if you need a phone number for JD let me know . also you can check with LAVOY , seems to me he had some after mkt clutch discs for less than JD.
ralph
02-07-2004 15:15:03
the price is right if eveything else is ok. where do you live? ralph
Karen
02-08-2004 16:25:30
 Re: Re: 440 dozer in reply to ralph, 02-07-2004 15:15:03
Ralph, Send me an email and I'll send you a link.
tom morstorf
02-07-2004 21:52:09
I live in kansas in Osage county. Ralph
