limb risers for 350 dozer
Herb
02-07-2004 19:25:26
Looking for limb risers for my 350c. Machine has the canopy already but no risers. Would prefer to get just the brackets for the risers if possible due to shipping costs.
Brenda
02-14-2004 16:45:36
 Re: limb risers for 350 dozer in reply to Herb, 02-07-2004 19:25:26
My husband has a set of factory limb risers with all four brackets, also the exteneded forestry rops that go on the side of the rops canopy.
Herb
02-15-2004 22:03:32
 Re: Re: limb risers for 350 dozer in reply to Brenda, 02-14-2004 16:45:36
Brenda.....Do you have any pictues, where are the parts located, are they for sale? I have high speed internet so pictues would be no problem on my end if you have any.
Brenda
02-19-2004 20:33:01
 Re: Re: Re: limb risers for 350 dozer in reply to Herb, 02-15-2004 22:03:32
Pictures are no problem, I tried to send you an e-mail but it came back. will try again
richard
02-09-2004 17:26:52
Herb i built the canopy and limb risers for my 440 also the fairelee and the two goose neck trailer.Just rember to weld the center brace in high unough to clear the hood when you get ready to take it off.
Mark
02-08-2004 17:01:50
Herb, If you are good at bending, cutting and welding metal I would make a pair. Be carefull with getting the upper brackets used because they are welded on to the ROPS and could be beat up if they were removed. The brackets on the hood/front end should be bolted on, so if you found those used, you should be ok. Be aware that if you don't space the bars apart enough you won't be able to lift the hood off without removing the limb riser - my 2 cents... let me know if you want a pic. -Mark
Herb
02-08-2004 19:16:24
 Re: Re: limb risers for 350 dozer in reply to Mark, 02-08-2004 17:01:50
Yeah, I think probably I will have to make my own. I have some 2" schedule 80 pipe that I could use. I have seen pictures of the risers but not a real close up. I figured they would weld on at the top. I figured to make a couple of stubs that I could weld on at the top and the pipe would fit over them. For the bottom I was thinking of making bolt on brackets with stubs that would fit into the pipe. That way it would be easy to remove them to get the hood off. Don't take the hood off very often. Would be nice to find a set to get a real good look at them. I'm pretty good at copying things for my own use. Any help greatly appreciated.
Mark
02-08-2004 20:20:25
 Re: Re: Re: limb risers for 350 dozer in reply to Herb, 02-08-2004 19:16:24
Herb, you can place the brackets so that the limb risers won't prevent you from removing the hood. Leave your e-mail and i'll send a pic. -Mark
Herb
02-15-2004 22:09:15
 Re: Re: Re: Re: limb risers for 350 dozer in reply to Mark, 02-08-2004 20:20:25
Mark..... Would like to see pictures if you get a chance. I thought my e-mail was available but I guess it wasn't. It is now I think. I have high speed access so large files are not a problem for me. Thanks in advance for any help.
Herb
02-10-2004 19:28:57
Thanks for the info guys. It looks like I will be fabricating some myself. Mark, some pictures would help greatly.
ralph
02-08-2004 20:04:21
i did mine with 5/8 grade 8 bolts and made the lower pipe go inside the upper pipe 2 feet and couldn't hurt it. ralph
jim
02-08-2004 09:38:07
I got a set for my d3 from a place in OK . They are sort of custom---just need to be cut to fit. They come in 2 weights-I got the heavier style and I think it was about $325 total. I think the place is KENCO--maybe someone else knows for sure. Jim
ralph
02-07-2004 22:03:50
i made my own just copy a 450 or 550. ralph
