420 c problems,,anyone have a idea?
Jim in michigan
02-10-2004 12:43:44
Went to use my 420 today and when I would try to push into the snow bank it would act like something locked up,, bog down and almost stall,, I noticed the left side turning clutch seems odd from how it was when I parked it,, could Ice do these things? I hope thats all it is,,I put it back in the barn and will leave it till the snow is gone and it warms up....Jim
Bernie in MA
02-11-2004 14:03:20
 Re: 420 c problems,,anyone have a idea? in reply to Jim in michigan, 02-10-2004 12:43:44
Jim, you may have gotten water into the clutch housing and it's frozen. There is a pipe plug on the underside of each housing. If you have a bellypan with dirt on it, it may be a while before you can get at it. I took the plugs out of mine and left them out years ago. They may take a 3/8 drive socket wrench (square hole) or a big allen wrench.
Jim in michigan
02-11-2004 16:36:44
 Re: Re: 420 c problems,,anyone have a idea? in reply to Bernie in MA, 02-11-2004 14:03:20
Thanks Bernie ,,, I hope thats all it is,,, I cant afford another major expense on a tractor or anything else,,just redid the engine on the ollie 66 and the ford 8n, put a clutch in the Farmall H so I am about tapped out on funds,,thats why I have some tractors for sale,,,Jim
Bernie
02-12-2004 05:53:26
 Re: Re: Re: 420 c problems,,anyone have a idea? in reply to Jim in michigan, 02-11-2004 16:36:44
If you can, take out the barrel plug on the front of the housing. You might be able to see evidence of water (frost all over everything). Bernie
Jim in michigan
02-12-2004 13:54:20
 Re: Re: Re: Re: 420 c problems,,anyone have a idea in reply to Bernie, 02-12-2004 05:53:26
I will try that,, then I am gonna turn on the salamander heater pointing at it,, dont worry I wont burn it or the new polebarn lol,,,Jim
