Change Steering Clutchs On IH 500C Info..
Scott
02-11-2004 22:29:57
i have found a 72 IH 500C crawler loader for sale. the steering clutches are shot. how big of a job are they to replace? what all has to come off to get to them. will i have to take off the rops also? and just a rough idea on how much the parts will be. any and all information would be very greatly appreciated..... thanks for your time.....
woodsman
02-19-2004 15:06:52
 Re: Change Steering Clutchs On IH 500C Info.. in reply to Scott , 02-11-2004 22:29:57
Sorry Scott, thought you recieved my email address. tspivak@vianet.on.ca By the way, whatever the manual says, you do not need to pull the pinion shafts out all the way. mail me before you start.
woodsman
02-13-2004 11:55:38
There is no reason whatsoever to take the sprockets off. I don't have rops on my machine so I can't say if you need to remove it. You will need to take all the linkages off the levers and take the top off the clutch housings. The clutches and brakes come out through the top. It's not that hard really, just dirty. There are some points that have to be followed to get them out and if you decide to purchase the machine email me and I will tell you how to do it. The 500 is a great little machine and not hard to work on.
Scott
02-14-2004 11:35:01
 Re: Re: Change Steering Clutchs On IH 500C Info.. in reply to woodsman, 02-13-2004 11:55:38
thanks woodsman. i am going to get the loader as soon as i get somebody to haul it for me. the guy has a shop book that goes with it and i am sure that will be a great help for me. i may be getting ahold of you sometime if i run into trouble and see if you can walk me through it.my email shoud be on this post. i could not get yours so if you can sometime email and i will let you know how i come out on it. thanks again woodsman. and also like to thank alll the others that posted on here..
t4mike
02-15-2004 08:16:26
 Re: Re: Re: Change Steering Clutchs On IH 500C Inf in reply to Scott, 02-14-2004 11:35:01
keep your eye peeled on ebay and get the ih blue ribbon service manuals for the 500 crawler. i think there are 6 total. as woodsman says its not bad at all, ive done my t4 and the earlier 500s are the same.
JimInOz
02-12-2004 17:36:40
If you get the machine,BUY a manual....best $$$ you'll spend.If I remember correctly,you have to ensure that you don't let any small parts fall into final housings.Good luck.
Steve
02-12-2004 05:00:29
third party image
Scott: It's not too bad a job if you have a decent place to work and some decent tools. You'll have to break the tracks and remove the sprockets. Then remove the right and left pinions. Pull the seat and fuel tank off. Then you can sometimes swing the Hyd tank and tool box off to either side, otherwise you'll have to remove them as well. Then you can remove the steering clutch covers and lastly remove the intermediate shaft from the bevel gear. Then they are ready to lift out. I may have missed something along the way, but those are the basics. They may not be in the exact order either. If you get into it keep us in mind for parts. We have new discs available as well as many other parts.
t4mike
02-12-2004 06:47:00
 Re: Re: Change Steering Clutchs On IH 500C Info.. in reply to Steve , 02-12-2004 05:00:29
why break the track and remove sprocket? isn't pinion access thru sprocket opening?
