580C backhoe starter problem
john5
02-12-2004 14:25:29
580C backhoe engine is hard to turn over--starter checks out ok--any help out there?
Jack
02-17-2004 17:29:18
 Re: 580C backhoe starter problem in reply to john5, 02-12-2004 14:25:29
John be sure to check your hydralic levers I spent thirteen hundry dollars and two weeks in the hot sun because the outrigger handle was engaged
John in TN
02-12-2004 17:18:42
I had the same thing happen to mine last year. It was corrosion inside the terminal end that hooks on to the starter. I replaced the battery and crimped a new end on the cable and it works great. This may not be your problem, but it fixed mine. John
Derek
02-13-2004 20:36:21
 Re: Re: 580C backhoe starter problem in reply to John in TN, 02-12-2004 17:18:42
It is common to have this problem due to hydraulic system building pressure while cranking. check all levers to make sure they are in neutral position.
