JD 1010 Crawler
Gary
06-09-2001 07:41:08
Can anyone tell me if info I was given is correct with regard to motor interchange? Currently crawler has 1010 gas motor. I was told a 2010 gas tractor or a JD 45 combine (some of them) would interchange. Thanks
440Sam
06-10-2001 13:19:01
 Re: JD 1010 Crawler in reply to Gary, 06-09-2001 07:41:08
The 1010 engine is the same as a JD115 power unit - this engine was in the 40 combine, 600 sprayer and a swather (don't know model). The 2010 and early (round back) 45 combines had the JD145 engines. They will bolt in but have more power. The block is the same in both the 1010 & 2010 just the engine displacement is different. The best fix is a 40 combine engine, if you can find one as they generally saw very little use and can be purchased for a few hundred $$. I sold one a year ago for $400. Look at the casting number on the front left side of the block - make sure the replacement is the same. Also try to find one with a spin on oil filter as these were the later model engines.
