New Holland LS-190 Axles
Jack
02-18-2004 05:14:12
Anybody figured out how to keep the axles from coming out of the New Holland LS-190 skid steer loader?
motrack
02-18-2004 19:45:04
 Re: New Holland LS-190 Axles in reply to Jack, 02-18-2004 05:14:12
give some more info. we are a NH dealer and dont have axles coming out of skid steers.
Jack
02-19-2004 05:38:49
 Re: Re: New Holland LS-190 Axles in reply to motrack, 02-18-2004 19:45:04
It's the front axels for the most part. The snap ring comes off and the axle comes out. It's a pretty simple axle retaining system consisting of a snap ring and shims. The shims are against the inner bearings inner race. Best I can tell is that, The bearing eats the shims which loosens the bearings. Then the lateral movement of the axle dislodges the snap ring. The axle comes out ruinning the bearings and seals. I've talked to quite a few other LS-190 owners around here and they are having the same problem. We use our LS-190 in a building stone business. I'll be glad to answer any questions to clarify my problem. Thank you
motrack
02-19-2004 20:09:21
 Re: Re: Re: New Holland LS-190 Axles in reply to Jack, 02-19-2004 05:38:49
to be honest I have not seen this in any we have sold. I havent seen a service bulletin but will look for something in dealer assist. give me you machine #. you can email me direct..... ....Rob
Jack
02-20-2004 04:51:42
 Re: Re: Re: Re: New Holland LS-190 Axles in reply to motrack, 02-19-2004 20:09:21
I appriciate it Motrack. We've tried about everything between us and the dealer. My dealer says that NewHolland isn't admitting anything at this point. It's been real frustrating for me. I use my LS-190 hard in a rock quarry and it's a strong little machine. I'm not sure which machine number you want?
motrack
02-20-2004 18:00:15
 Re: Re: Re: Re: Re: New Holland LS-190 Axles in reply to Jack, 02-20-2004 04:51:42
machine serial #..... ..... thats the 1st thing NH will ask me when I go online into dealer assist to see if there are others having the same problem and what the fix is. wont promise you anything but will help if we can.
Jack
02-21-2004 17:06:52
 Re: Re: Re: Re: Re: Re: New Holland LS-190 Axles in reply to motrack, 02-20-2004 18:00:15
Serial number is 196286.
