d-2o direct drive clutch adjustment
ray
02-20-2004 12:23:05
gears grinding when shifting, tried increasing linkage travel, now its hard to get in gear and tracks don't spin under load. There is numerous linkages to adjust and two arms on bell housing plus a brake band around drive shaft. Any insights or experience on this?
Darin
02-20-2004 20:20:27
 Re: d-2o direct drive clutch adjustment in reply to ray, 02-20-2004 12:23:05
Put the linkages back to where they were. Then get your self some manuals to give you all the info you want. It sounds like you can just adjust teh inertia brake band to stop the drive shaft before attempting to shift gears. If you have trouble getting info or parts contact me. Darin
JimInOz
02-20-2004 20:01:43
If it's a Kom D20,the trans braking band may need adjusting.Go buy a manual,as it will give you the specs & save you many $ over machine life.Jap parts are not cheap.operator manual may cover all adjustments.
