JD 1010 cracks
ktmdan
02-21-2004 11:02:31
I actually read allot of the threads posted on 1010's before I asked this one. I normally just post then start looking. I've just started looking at a 1010, havent found the owner yet, and was wondering if these rearend cracks I've read so much about are obvious or hidden? Where should I be looking exactly? I'm actually new to this but do have some knowledge of crawlers just not all the proper names for different areas and parts. I have a great job that takes me to allot of small, even tiny towns around the eastern half of SD, southwest MN and northwest IA. If anyone is looking for something let me know. I found the 1010 in a town of 65. Thank you again, Dan
ktmdan
03-02-2004 10:41:20
 Re: JD 1010 cracks in reply to ktmdan, 02-21-2004 11:02:31
Scott, Ill keep my eyes open and my camera handy.
scott
02-21-2004 21:35:21
looking for t or td 340 int prefer 4in1 bucket or same size crawler with 4in1 tx
jdemaris
02-21-2004 20:13:49
1010 crawlers were prone to cracking the intermediate housings; i.e. the cast housings between the transmission case and the final drives. Deere updated them a long time ago to 350 housings, so if they ever broke the crawler probably has the heavier updated housings on it now. They also tend to crack the steel side-frames near where they bolt to the final drives. One other trouble spot, if the crawler has the optional hydraulic reverser, is where the reverser housing bolts to the transmission case. It this looks like it's loose, and has been loose for a long time, it's could be a major repair to fix because the locating dowells get wallowed out and subsequently the the reverser output shaft gets out of alignment with the transmission input shaft.
fasteddy
02-21-2004 16:55:46
Dan, this goes for any of the small jd's that I'v been around. They are all good if you take care of them and treat them fair.I have seen them crack at the final drives where the bearings are located.Usually bearing will wear out and cause slop then pressure will crack housing.The area is usually all dirty under there so some might over look any crack.Two places to check, Where shaft comes out and up above where bearing is inside on shaft.Check over good !!!!!
Robert
02-21-2004 11:11:09
Hello ktmdan. I have an original parts catolog for the 1010 crawler. Please let me know if it is of interest to you. Thankyou. Robert.
ktmdan
02-21-2004 11:16:28
 Re: Re: JD 1010 cracks in reply to Robert, 02-21-2004 11:11:09
I may be interested Robert. You say original, does that mean it's from John Deere? It needs to cover the early model with screw type track adjustment. Let me know. Thank you, Dan
Robert
02-21-2004 11:48:27
 Re: Re: Re: JD 1010 cracks in reply to ktmdan, 02-21-2004 11:16:28
Hello. Please email me . I,ll give you a full description. Robert.
ktmdan
02-21-2004 16:44:24
 Re: Re: Re: Re: JD 1010 cracks in reply to Robert, 02-21-2004 11:48:27
Robert, Am I missing your address somewhere? When I click on your name it says your address is hidden. Try mine. Or my cell is 605-351-7265 and you can leave it on voice mail. I may get your call but the ringer stinks. Dan
