Case dozer/loader model 600
wayne
02-21-2004 20:10:56
Bought a 6oo case terratrac loader with the left side track half on half off . the track adjusting bolt is frozen solid ,tried heating but to no avail. Also tried squirting with cr56 and blaster pentrating fluids but still no use . Does anyone out there have any good sugestions on what to do to get this thing free? Also need the brake drums and shoe assemblies with backing plates as someone must have had problems with brakes in past and tossed them out ... thanks ....Wayne in Wisconsin.
Robert in W. Mi
02-22-2004 14:45:13
 Re: Case dozer/loader model 600 in reply to wayne, 02-21-2004 20:10:56
Did you know there's a group of Case Terratrac owners on Yahoo that share info??? There's some good info there. Robert
wayne
02-22-2004 19:47:05
 Re: Re: Case dozer/loader model 600 in reply to Robert in W. Mi, 02-22-2004 14:45:13
Thanks so much for that info robert...maybe I'll have some luck ...hopefully someone has had this problem before and its secound hand news ....Wayne
jim/pa
02-22-2004 06:04:39
it takes alot of heat to loosen the nuts up. first clean the exposed threads, then heat cherry red they will only move a quarter turn before they cool down, heat again, turn, repeat til you're on clean threads. takes about an hour a side. when you have them free apply anti seize compound to prevent reoccurence.
wayne
02-22-2004 19:42:55
 Re: Re: Case dozer/loader model 600 in reply to jim/pa, 02-22-2004 06:04:39
Thanks jim for the thoughts but already tried the heat method couln't get to budge a bit ,do these bolts turn opposit rather then the counter clockwise to loosen ?....anyone have any other ideas?
