Fuel gage for Case 450 crawler
beaker
02-24-2004 19:51:39
Does anyone know of a fuel gage add on for 1976 Case 450 crawler? Or am I the only fool that runs out of fuel?
marlowe
02-25-2004 16:15:51
 Re: Fuel gage for Case 450 crawler in reply to beaker, 02-24-2004 19:51:39
i have 3 450s and they do not make a fuel gage for them but i made gages for 2 of them.i used a clear plastic tub and run it up the back of the tank so it is protected a little . first run it out or drain the fuel out and get as low on the tank as you like and drill a hole and then put a self tapping fitting in and then drill hole on the top and do the same as the lower. i used all plastic fittings and sealed ever thing with some stuff like JB weld but it was a putty . no leaks in 5+ years . there are many ways to do it thats just the way i did it
beaker
02-25-2004 18:34:39
 Re: Re: Fuel gage for Case 450 crawler in reply to marlowe, 02-25-2004 16:15:51
Thanks Marlowe, you have given me an excellent idea. I will simply make a sight tube similar to yours. I think I can install it in the battery compartment. Anyway you got me headed in the right direction once again.
