3414 Transmission
Chuck Roberts
02-29-2004 13:42:36
Have a 3414 IH backhoe. Old iron runs good and the backhoe still strong. Only problem is forward gear on transaxle. Keeps coming out of gear and makes an awful grinding noise. Reverse is fine. Anyone know where I could find salvage parts?
Chappy
03-01-2004 18:11:13
 Re: 3414 Transmission in reply to Chuck Roberts, 02-29-2004 13:42:36
Chuck:
I have a Diesel 3414 that I plan to part out real soon. The transmission worked fine, I broke some teeth on my ring and pinion gears. I going to use the engine for something else.
Chuck
03-13-2004 05:33:32
 Re: Re: 3414 Transmission in reply to Chappy, 03-01-2004 18:11:13
To Chappy. Do you have parts for the 3414? Will take whatever you don't need or want.
Chuck
Chuck
03-05-2004 18:04:49
Let me know where you are and I may want what's left of your trans.
Reply to chuckrts@msn.com
mike
03-01-2004 18:02:28
Hi chuck i have a 3414 parts machine was diesel the reverser died and they put motor in something else some reverser parts may be ok and trans im sure is let me know what you need and ill see what i got good luck mike
Ben Gage
12-05-2004 11:55:51
 Re: Re: 3414 Transmission in reply to mike, 03-01-2004 18:02:28
Saw your message, I have a 3414 industrial, the reverse gear went bad,and I may need another trans, do you still have yours. Thanks, Ben.
Chuck
03-05-2004 18:03:07
Beggars aren't chosers. What do you want for what's left of the Reverser?
Reply direct to chuckrts@msn.com
Bill
03-01-2004 15:48:59
These tractors are /were made in England. Mainly imported into Canada. Some found their way into the States. If it helps your search, the red farm version of that tractor is a B414.
Also might try Mike at the following E-Mail, gause@valunet.com A Texas International Dealer VERY knowledgable about the 3414's & B414's
