JD 350c
Dirthog
02-29-2004 15:27:45
My buddy is a logger who swears by JD machines. I had decided to buy a jd350c but after reading some of the posts on this site I am now also concidering case dozers. Which case dozer is the equivalent to a 350c deere ? Which would you buy, the jd or the case and why ? I've been having trouble finding machines like the above for sale, any good spots to look ?
this is a great site, thanks.
gatractorman
03-02-2004 02:50:02
 Re: JD 350c in reply to Dirthog, 02-29-2004 15:27:45
In my area there is probably a 7 to 1 ratio, you see 7 JD's for every 1 Case so quite naturally your going to have more trouble out of the JD's just because of the number of them, not knocking Case (if it pushes dirt I like it) they are a good machine but dont let the responses here affect your decision this is a great place to get info. it is not the final authority about how to spend your money. Case made 350 and 450 machines that were comparable to JD 350, 450.
jdemaris
02-29-2004 18:04:18
I was a Deere mechanic for a long time, so I'm familiar with the 350 series. Mechanics, thought, see more broken machines then good ones. We had a lot of loggers that used them for bunching trees to the skidway where a skidder would do the rest. They're a rugged machine, but a 450 Deere will do a lot more, and hold up much better if you're going to work it hard. I have to say, though, I know of quite a few ex-Deere guys that have changed over to Case machines with power-steering. By power steering, I mean that some of Cases keep power to both tracks when turning, whereas the 350/450 series Deeres don't. As far as a Case that's equivalent to a Deere 350, I don't know of one. The little Case 310s and 320s are lighter then the Deere 350 but have bigger engines. I'll assume the 450 is as heavy, or maybe a little more than the 350 Deere. I've got an Allis Chalmers HD4 which is just a step about the Deere 350 and a step below the Deere 450.
Doug
02-29-2004 16:02:50
I had a JD 350 about two years ago was a good machine, Then I aquires a 450 Case and Inquired on this board when one I should keep and the vote was unamus to keep the Case, I'm not sorry I did,The Case Has not given me any problems have sent several hours on it building ponds, road work,clearing trees, etc. I'm glad I listened to the experts on this board. Hope this helps. DOUG
