case 310 g injection pump
robert
03-01-2004 17:36:46
dozer has been sitting a while has 188 g diesel fuel to pump but no fuel to injector lines how can i remove this pump have no manual but looks as if i have to remove front engine cover to acc. pump drive gear or does it slide off after removing mounting bolts .
marlowe
03-01-2004 20:36:04
 Re: case 310 g injection pump in reply to robert , 03-01-2004 17:36:46
have you went trought all the bleeding of the system?
jdemaris
03-01-2004 18:37:38
On the 188D or 207D engines, the Roosamaster pumps slides off the shaft after you remove the two bolts or nuts. No need to remove anything else.
