Fluids and operators manual for Case 450 Dozer wit
Jerry Dickerson
03-03-2004 16:37:03
I recently purchased a 450 with a 188 engine and have completely rebuilt the engine outside the frame. Runs great and I really like it. I have the service manual and would like to get the operators manual. Also what brand hydrualic fluids as I've been using a non foaming oil of different brands (not the cheapest but not brand names either) so long as it met case standards. Is this ok or should I use a certain brand. I use Shell Rotella 15-40w for engines.
Jerry Dickerson
03-03-2004 19:12:26
 Re: Fluids and operators manual for Case 450 Dozer in reply to Jerry Dickerson, 03-03-2004 16:37:03
Thanks for the information. I've just found this forum and already have learned a lot. Will check often but hopefully want need to much advice on repairs but is good to know all the experience is available.
marlowe
03-03-2004 18:29:55
the oem oil for the power shift and TC is TCH and that is from CASE but there is after market stuff that says it is TCH but i have never used it and will not one thing i don't skimp on is oils. for the hyd.system you can use TCH or a good grade hyd. oil and rotella 15-40 is great for the engine
JCmarleau
03-03-2004 17:13:15
I do have a operator manual my e mail is jcmarleau@aol.com
