TD 20 200 rollers and rail height
T.C. Mallett
03-04-2004 08:30:53
Most of the bottom rollers on my TD 20-200 are worn out. The track rails are getting rolled over on the edges. Two questions:
1. What rail height is acceptable? Mine measures 4 1/4 inches from the track pad to the top of the rail. Is this enough to justify putting new rollers on the machine.
2. Does anyone have a source for used rollers for this machine? There are 6 rollers on each side with 3 being double flange and 3 being single flange. The bolts holding them on have a 1 1/8 head size.
I am located in Austin, Texas. Thanks for your input.
T.C. Mallett
03-07-2004 18:28:22
 Re: TD 20 200 rollers and rail height in reply to T.C. Mallett, 03-04-2004 08:30:53
Thanks for the replies. I did locate 12 new Berco rollers thru Waco Equipment. That is only about 100 miles from home. They should be ready to pick up on Monday.
It does concern me to spend nearly $3,500 on the machine at this stage in its life, but hopefully I can get that much more use out of it around the farm.
chappy
03-06-2004 04:42:21
T.C.
I think I have a complete set of new rollers that will work for you located in Southern California.
Chappy
Sean
03-04-2004 09:07:22
TC, Below is a link to a good website with the specs on your tracks. Good luck...
