Fuel Pump
Doug Ont
03-05-2004 16:01:44
How much pressure should I have at the injector end of the fuel line on my Ford 3Cyl Diesel. I cracked the lines at the injectors to see if the fuel was reaching them and there was a small amount of pressure but I do not own a guage to check it out, but will locate one to run some further tests.The check I did was after cranking and it only seemed to spray very little and then dribbled out. Any help would be most appreciated.
captain crunch
03-06-2004 10:19:07
 Re: Fuel Pump in reply to Doug Ont, 03-05-2004 16:01:44
The pressure should be around 1500 to 2000 psi at injector. So be careful fuel under that press can and will cut like knife. Brian
Doug Ont
03-06-2004 16:15:50
 Re: Re: Fuel Pump in reply to captain crunch, 03-06-2004 10:19:07
Thanks for the info, and yes, I kind of assumed that what I had was to low a pressure, will get a gauge and check it out further. The pressure that you stated is that static pressure or when cranking.
captain crunch
03-08-2004 21:37:27
 Re: Re: Re: Fuel Pump in reply to Doug Ont, 03-06-2004 16:15:50
That is cranking pressure
Brian
