The value of an older crawler is largely determined by how good the U/C is. The better the U/C the more money that it is worth. There are many fine older machines out there. JD is good, AC is good, IH is good. Some models are toughter to find parts for and some parts are not available for some machines. While engine parts are usually available, it is the high wear parts that become the most difficult to find such as rails, rollers, idlers, sprockets ect. If you find a good JD take it and go from there. If not look at TD9 or the HD5/6 by AC. Form the sounds of what you want to do, you are almost calling for a light project tractor. Need not be perfect. Look at www.ibdozing.com on the discussion formus there. Is is broked down by tractor make and so you can get a good idea what peole are saying. Now no matter what you buy, unless it is almost new, you will spend more time working on it than running it. I know I have 4 that way plus at that same time helping a buddy on number 5 right now rebuild his hudraulic systems and have added a 15Ton Mobile crane to the mix. That is also the fun part of this stuff, How to I fix it to keep it running. Like the surrealist play "Waiting for GODOT" Good luck hope you find a good one
