I recently purchased a 941B Traxcavator serial #70H3337. The machine has been working fairly well until a couple of weeks ago. I am using the machine to clear a long driveway on my land. I am fairly new to operating crawlers, however; I have operated backhoes and bobcats before but I am not a very experienced mechanic.After running the machine for about 45 minutes to an hour, the engine starts to sputter and eventually dies out. If I leave the machine for a day or so, It will start up again an run again for about the same amount of time. I don't work on it every day, so it's hard to say how consistent the problem is. I changed the fuel filter and replace the fuel line. After removing the fuel line from the engine, it seemed to not be flowing very well. I did not have a compressor or anyting to try blowing out the clog, so I just replaced the line and the filter. I also cleaned the smaller wire filter that is in the bulb shape metal container underneath the feul system. I figured that this must be the problem, however; after working about an hour, the problem started again. Does this sound like a fuel pump problem or something more serious? Any reply's to this message would be greatly appreciated. Sincerely, Frank
