Cat 426 backhoe with problems in rear end or brake
O Smith
03-08-2004 19:27:32
I have a Cat 426 series II backhoe that started giving problems all of a sudden. Oil is driping from the right rear drive axel housing where the brake acuater rod goes into the read end housing, and the housing becomes very hot ( to hot to put you hand on ) in a very shot distance of driving as in 500 yards. If it were Only an oil leak that I could understand but why the heat?? the brakes are not on. Any answer of suggestion greatly appricated. O Smith
Bob/Ont
03-09-2004 05:43:05
 Re: Cat 426 backhoe with problems in rear end or b in reply to O Smith, 03-08-2004 19:27:32
Drain the oil out of the axle and I think you will find it full of metal. The only thing you can do is pull the axle to work on it. If the brake is free then it's likely something grinding up in there. If the oil is clean get both wheels off the ground and double check the brakes are not dragging. Check your linkage pins and all pivot points are not seized too.
Later Bob
