chains???
bcwv
03-11-2004 17:22:15
Could someone tell me what chains are on a Case 450. I have a farm and am looking to buy a dozer and the one i'm calling about the fellow said the chains have not been turned, they are still on the same side as when he put them on new. Thank you
Cory M
03-12-2004 11:03:24
 Re: chains??? in reply to bcwv, 03-11-2004 17:22:15
I have a question about the sprockets. Is it possible or advisable to swap sides with the sprockets? Mine seem to be wearing mostly on the foward driving side and not so much on reverse side.
T!Roy
03-17-2004 22:26:42
 Re: Re: chains??? in reply to Cory M, 03-12-2004 11:03:24
Cory
To use up your sprockets fully this is incouraged. Usually rotated when you turn your pins&bushings. You will get full side of sprocket cup pushing on fill side of bushing. Don't get anxious your chain will snap when in reverse. Keep track tension proper, you can run the sprockets out till you can shave on them.(the sprocket tips will wear to a sharp edge) Good Luck!
bcwv
03-11-2004 18:18:23
Thank You Broken.
Brokenwrench
03-11-2004 17:33:23
The "chains" are the movable links that make up the tracks. They have bushings on them that should be turned 180 degrees(pressed out by a track shop,rotated 180 degrees and pressed back in)as they wear. You want to "turn the pins and bushings" before they wear through.You should also replace the sprockets at this time so the curve in the sprocket tooth matches the curve on the bushing so as not to cause abnormal wear. A pin and bushing turn,and a new set of sprockets will run $700-1000 depending on who does the work and if you buy OEM or aftermarket sprockets,if the shop does the removal/reinstall of the tracks.
bcwv
03-11-2004 18:40:52
 Re: Re: chains??? in reply to Brokenwrench, 03-11-2004 17:33:23
Do you know what the difference is between the different case 450's. like case 450, 450b and 450c etc.
Karen
03-12-2004 03:04:09
 Re: Re: Re: chains??? in reply to bcwv, 03-11-2004 18:40:52
The letters stand for years 450..1965-1969 450B...1979-1983....450C1983-1993 Now remember every letter newer you go means a bigger diamond you must buy your wife to please her for you buying this toy! So the further you go up the alphabet the more it will cost you.
bcwv
03-13-2004 17:17:11
 Re: Re: Re: Re: chains??? in reply to Karen, 03-12-2004 03:04:09
Karen..... now.... what would give you the idea that she likes diamonds? I almost had her convinced they were ugly! Thanks for the info
