Degresing
youngster
03-12-2004 18:47:49
i am looking to degrese my Td-14. the grese is prety thick on the block. how is the best way to do this. i have been spraying it down with diesel and that work for the heavy stuff but i want to get the diesel residue off to paint.
JD dozer mike
03-17-2004 18:01:07
 Re: Degresing in reply to youngster, 03-12-2004 18:47:49
Best thing i have found is, spray it down with degreaser let it sit a few hours. then hit it with a hot steam jenny. works good and will get the lose paint off too.
Ben Hodges
03-14-2004 18:19:25
For final cleaning try Westley's Whitewall cleaner,then rinse, Dry, Paint. simple and inexpensive
Wayne
03-12-2004 21:13:24
Working on old cranes I've seen some heavy, mean grease. The best thing we've found for the "normal" stuff is Grease Gone. Sorta like Purple Stuff but it seems to work better. For the really mean stuff get a few cans of oven cleaner and spray it on and let it set for a while to break everything loose. Rinse it off good and it'll be about as clean as your gonna get it short of using a steam jenny. You have to be careful with it though as you can imagine. Wear the right protective gear when your using it and if you leave it on too long, it will remove the paint along with the grease. Good luck.
Wayne
03-12-2004 21:10:03
