440 IC Bucket Cylinders
BobMo
03-14-2004 07:06:20
Can I put new seals in the bucket cylinders (not lift) without removing them from the unit or do I need to take the things completely out of there?
Brokenwrench
03-14-2004 07:30:57
 Re: 440 IC Bucket Cylinders in reply to BobMo, 03-14-2004 07:06:20
They can be repacked in the tractor,just remove the rod end from the bucket linkage after you get the packing nut loose. Pull out the rod/piston,block it and put the rod pin back in the linkage to hold it from turning while you take the piston nut off.
