McCromick Deering T20 parts tractor
Martin Caldwell
03-15-2004 07:03:41
I have a parts tracor that has some good parts left. Need something let me know.
Eugene Faber
05-03-2004 21:03:01
 Re: McCromick Deering T20 parts tractor in reply to Martin Caldwell, 03-15-2004 07:03:41
Do you still have any parts left? If so, let me know. I just bought one and haven't unloaded it yet. Not sure what all I would need. Do need an air cleaner, hood and side panels. May need sleeves and pistons. Could use chains. Thanks
cat15vet
03-16-2004 19:02:14
I need the PTO output shaft and bearing cover that is triangular through which the PTO shaft runs. Do you have a belt pulley?
G CONN
03-15-2004 19:51:05
Martin, I could use a starting crank assembly, rear toolbox and one of the side peices that covers the opening along the side of the fuel tank at the bottom( I will check which side)
G Conn
03-16-2004 13:54:36
 Re: Re: McCromick Deering T20 parts tractor in reply to G CONN, 03-15-2004 19:51:05
Martin ,I cheched ,need right side (as you sit in seat)cover and I already have a hand crank. Gordon
JerePa
03-15-2004 19:16:42
Could use an air cleaner, good set of tracks & sprockets, a aluminum "International" emblem for the radiator. Maybe some other bigger stuff depending where you are. Thanks, Jere
