Track question
Brian
03-21-2004 13:07:30
Had good advice on keeping fingers out of the way. Track is back on so I have another question. We had to fight with jacks & a come along. Seemed like we were fighting torque on the track depending on where we were using the come along. Is there a trick to pulling ends together or did we make it harder than it had to be?
Oldfarmboy Jim
03-21-2004 21:36:31
 Re: Track question in reply to Brian, 03-21-2004 13:07:30
I bought an army surplus track jack from a surplus outfit on eBay. $25 + $16 shipping. A great investment. First time I ever did track work. The track jack took all the work out of bringing the links together and no pinched fingers. The right tool always makes tough jobs go smoother.
Brian
03-22-2004 18:46:17
 Re: Re: Track question in reply to Oldfarmboy Jim, 03-21-2004 21:36:31
Looks like they have a 16", 18" or 19"- all models look a little different in the jack mechanism- an internal screw or turnbuckle type. Which do you have?
Oldfarmboy Jim
03-23-2004 15:52:47
 Re: Re: Re: Track question in reply to Brian, 03-22-2004 18:46:17
I bought the 19" screwjack. It worked great for me. Coleman's Surplus has an eBay store and they were pretty quick to ship. Enjoy, Jim
Brian
03-23-2004 16:55:22
 Re: Re: Re: Re: Track question in reply to Oldfarmboy Jim, 03-23-2004 15:52:47
Thanks- I ordered one last night from Coleman's- also found them on another site but higher price & more shipping. Thanks for steering me the right way before.
Brian
03-22-2004 06:18:16
Thanks, sounds like I should be in the market for one. Any leads?
VaTom
03-21-2004 16:29:44
Brian, when I had a 440 (about the same size as yours) I got so much practice that I could split the track and replace the final drive bearings by myself in under an hour. Used wood blocks to support the track and a comealong to pull the ends together. This was after I released all track tension. Shouldn't be a problem and I certainly hope you don't get as much practice as I did.
Oldsalty
03-22-2004 08:26:17
 Re: Re: Track question in reply to VaTom, 03-21-2004 16:29:44
I use the blocks of wood and come-along method on my Oliver HG. The wood blocks support the track and the come-along pulls it together. And I didn't need to back off the track tensioner.
fasteddy
03-21-2004 15:39:27
Brian, I was usually by myself and this worked good for me.I had one 3/8 binder , two s hooks that car haulers use and two short pcs of chain.I would let press off of track totally and then put track on and get it as close as I could by hand and chain there. I would use blocking under top of track to hold even ,then use binder to bring the two together.Hope this helps The s hooks were made to go in a 1/2 inch hole and other end would acept a 3/8 chain!!!!
