jd 450e longtrack dozer pressure loss in reverse
Gary
03-21-2004 13:32:08
I have a 1987 jd 450e longtrack dozer and after running a couple of hours I have to bring the rpms up to get it to go into reverse seems like a pressure loss in the hydraulics when the oil gets hot . Any ideas? Also looking for a seat for it.
Jonathan
03-21-2004 16:03:13
 Re: jd 450e longtrack dozer pressure loss in rever in reply to Gary, 03-21-2004 13:32:08
If it slips in reverse...and pushes ok in high and low forward, then the transmission has to come apart...there is a clutch pack in there for high forward---low forward...and one for reverse...entailas removing engine, dash console assembly, clutch housing and transmission top cover....then remove the "H-L-R" clutch assembly..
Gary
04-26-2004 18:15:28
 Re: Re: jd 450e longtrack dozer pressure loss in r in reply to Jonathan, 03-21-2004 16:03:13
Thanks for the info and sorry for the long delay in responce computer problem. Do you know where to get a shop manual for this machine? thanks Gary
