That's always a crappy situation, and it's likely to happen just as it's getting dark or starting to rain and you're rushing to get something done. Or you're wife is pissed that you're running late. Anyway, a couple more suggestions to add to those already posted by others. First, be really, really careful, especially on the downhill side of the machine or if you're jacking it up. 2.I would put in a temporary hydraulic hose so that you have the hydraulics availble to help you. 3. My objective would be to first get the machine level. If you're clever, you can do this and almost everything else using the machine's hydraulics. For example, by alternately raising and lowering the blade and putting logs or 6x6's in the right places, you can use a seesaw effect to gradually raise the machine on the bad side. When the track is off the ground, it already starts to look a lot more promising. 4. To pull the track around and line it up, you can hook chains on it and pull it by moving the blade. If you have two ways to move the blade (e.g., up and angle), you can use each on one chain (one on the top and one on the bottom), a little at a time, then readjusting the chain location. 5. When you're real close to popping it on the idler, you can use the engine power, braking the track on the other side and moving the one in the air a little at a time, and it will go right on nicely. It all involves being clever in positioning the chains and in being patient about readjusting their position after every slight movement. But I still find this faster (and safer) than trying to muscle it all into place. Save those pictures as a reminder to listen more carefuly for a track that is getting ready to come off! :)
