Case 188 block
Karen
03-23-2004 04:01:36
If I was looking for a Case 188 diesel block what should I have to pay for one??? Looked at 580 backhoe that needs one and was wondering what a bock was worth.
jdemaris
03-24-2004 05:46:31
 Re: Case 188 block in reply to Karen, 03-23-2004 04:01:36
I'm not what you'd call a Case enthusiest or expert so my knowledge is somewhat limited on the matter of prices. I have a low-hours 207D that is a bolt-in replacement for a 188D and was offered $1000 for it. I didn't sell it because I've got a 580CK hoe sitting in my shop with a blown 188 in it. Been almost four years now. My intention was to swap engines, but so far I haven't gotten around to it. Picked up two running hoes since pulling the Case apart, so I no longer need it. Thus my lack of inspiration. The 188D that's in it has a hole in the side of the block where a rod is peeking through. Must be a common thing in 188Ds, because I've seen a lot of them with patches in that block area. It's a non-strategic spot, i.e. no coolant or oil galleries. Anyway, I'd love someone to come and buy the whole mess; I want it out of my shop. I've been hesitant to drag it out, because it's too much work to get it back in if I decide to fix it. The machine itself is about as beat as one can get and still be used. Pins loose all over the hoe and loader, and lots of crappy welds and braces. But . . . it was being used daily until the guy was plowing snow with it and the rod wanted to see the outside world. Trans. and hydraulics were working fine. Anybody wants the mess, take it all for $2300. Blown 188D is G188 #2646771. Machine is 580CK ser. # 8336306. Replacement engine is 207D, ser.# 4307581. I'm in central New York state near Cooperstown, Oneonta, and Cobleskill. At present, the front end is off the machine and old engine is ready to come out. My email address is jdemaris@capital.net Don't contact unless interested in the whole mess.
Mike D.
03-23-2004 04:18:58
Same thing here. We're looking for one for a 450 loader. I've found complete engines, but no short blocks. Several Case tractors had them. Some have differant splines then what we need. Please post the information when you find one.
marlowe
03-23-2004 07:52:58
 Re: Re: Case 188 block in reply to Mike D., 03-23-2004 04:18:58
188 blocks a in short supply because there are no new ones lift.my locale case dealer got the last 8 from case to build engines for a state contract so the best you will get are used
Mike D.
03-23-2004 08:55:58
 Re: Re: Re: Case 188 block in reply to marlowe, 03-23-2004 07:52:58
Thanks Marlowe, Used is what I had thought all along. Been looking. Got one that's in your way? LOL! Mike
jim/pa
03-23-2004 13:53:28
 Re: Re: Re: Re: Case 188 block in reply to Mike D., 03-23-2004 08:55:58
hey guys, i have an older 310 crawler parts machine with a diesel, parts engine. i assume its a 188. the engine was set up when i acquired it with another machine. i poured fuel down the exhaust, and covered it. i havent tried to turn it since. it has the older style injectors, but the pump appears to be the same as the roosamaster on my 310g. is it worth anything?
jim
Mike D.
03-23-2004 16:23:28
 Re: Re: Re: Re: Re: Case 188 block in reply to jim/pa, 03-23-2004 13:53:28
May be that we can dicker. Is the engine pulled?
jim/pa
03-24-2004 12:13:41
 Re: Re: Re: Re: Re: Re: Case 188 block in reply to Mike D., 03-23-2004 16:23:28
it is loose inside the frame, bellhousing is off, has pump, both manifolds, water pump, no fan, havent had valve cover off yet, flywheel looks good. wadda ya got to dicker with?
Mike D.
03-25-2004 05:04:16
 Re: Re: Re: Re: Re: Re: Re: Case 188 block in reply to jim/pa, 03-24-2004 12:13:41
Hello jim/pa, Email me the details on this 188 and we'll go from there. Mike
hahaha
03-24-2004 13:35:53
Now I got to put my thinking cap on. Mike D.
