350 Starter Solenoid
Wingnut
03-25-2004 17:01:58
We were up and running for awhile after a complete reversor rebuild....Ran dozer for a day went to start next day ....woouldnt start.Pulled starter ....tested it..... needs new solenoid.Question being ...Is there a automotive solenoid that will replace the one thats bad or is this a nother Deere item.Starter is a delco.#1107863-7 for a diesel.
wing
Wayne
03-26-2004 05:50:44
 Re: 350 Starter Solenoid in reply to Wingnut, 03-25-2004 17:01:58
You can probably buy it from Deere cheaper than anywhere else.
Wingnut
03-26-2004 07:01:10
 Re: Re: 350 Starter Solenoid in reply to Wayne, 03-26-2004 05:50:44
Got one at auto zone 12 bucks....Id be really suprised if it was cheaper from Deere.
Wing
jdemaris
03-25-2004 18:52:52
I forgot to mention that the only difference between the gas and diesel solenoid on your Delco starter is the big return spring - the rest is the same. That's why your solenoid has an "r" terminal on it which is meant to be used as an ignition-resistor bypass on gas engines.
jdemaris
03-25-2004 18:48:59
Same solenoid on an older V-8 Chevy starter, it's a very common one. Also, you can usually pull the cap off and reverse the contacts instead of replacing it.
Wingnut
03-26-2004 04:31:16
 Re: Re: 350 Starter Solenoid in reply to jdemaris, 03-25-2004 18:48:59
Thanks Again JDE i thought it looked pretty common.....I already did Try to reverse the contacts but the copper winding wire broke off the terminal.....Off to autozone today.
Wing
