JD430 reverser
Jerry
03-26-2004 06:33:09
The reverser on my JD 430 is stuck in forward.The cause was low oil in the case. A while back there was a post about removing the reverser and just going with the transmission. How do I remove the coponents that will allow just the transmission to be used?
Thank you
Karen
03-27-2004 05:35:37
 Re: JD430 reverser in reply to Jerry, 03-26-2004 06:33:09
I know where there is a 430 without a reverser being parted out. Email me and I'll send you a link
Lavoy
03-26-2004 14:39:58
You need to remove the center section from the crawler, and remove all of the internal pieces. You will then need to purchase the replacement shaft and coupler. After these are installed, you reinstall the empty center section.
Lavoy
