Case 450 Dozer...quit on me
Nate Brown
03-28-2004 20:42:56
I was clearing a field the other day, and I shut down for a few minutes. When I cranked back up the dozer would NOT move. It acts like it is in neutral. Can anyone tell me where the hydraulic filter is on this tractor?? It's a '77 model. Also I need a shop manual. Found one, it was $300. That sounded pretty dern expensive to me.
Ric
03-29-2004 14:43:27
 Re: Case 450 Dozer...quit on me in reply to Nate Brown, 03-28-2004 20:42:56
I bought an operators manual for about $20.00 and it gives you a lot of info. When I need a shop manual, I go to the Case dealer and he gives me copies out of his manual, whatever I need. I do buy some parts there but not all. The parts man has been very helpful.
Nate
03-29-2004 18:21:53
 Re: Re: Case 450 Dozer...quit on me in reply to Ric, 03-29-2004 14:43:27
Thanks Ric. Can you tell me how to pull the hydraulic filter? This is the first crawler I've ever owned. I can take care of the engine, but the transmission, running gear etc. is a lot different from a farm tractor.
Nate
03-30-2004 18:01:03
 Re: Re: Re: Case 450 Dozer...quit on me in reply to Nate, 03-29-2004 18:21:53
Thanks again Ric, I talked to a guy today who used to run several 450's in his dirt business. He said he thought he had an old operators manual in his storage building, and he'd let me have it. Again thanks for the help.
Ric
03-30-2004 17:25:02
There is a suction line and a pressure line. the suction line is on the right hand side in the engine compartment. Take the 4 bolts out and off it comes. When I cleaned mine, it was so dirty I do not know how it ran. The pressure filter is under the right side compartment where the controls are. Just take the plate off and the filter case has a big nut on the end. I found this very dirty also. Make sure you get an operators manual asap, best money you will spend.
Good Luck
BUTCH
03-30-2004 03:51:37
sounds to me like you parked it facing slightly up hill and it lost its prime on the pump.
Nate
03-30-2004 06:06:09
 Re: Re: Re: Re: Case 450 Dozer...quit on me in reply to BUTCH, 03-30-2004 03:51:37
It's parked on flat ground, but it WAS low on oil. How do you re-prime the pump??
butch
03-31-2004 04:10:05
 Re: Re: Re: Re: Re: Case 450 Dozer...quit on me in reply to Nate, 03-30-2004 06:06:09
ON THE RIGHT SIDE OF THE ENG YOU HAVE A FILTER AND A BLACK HOSE THAT RUNS TO THE PUMP ON THE RIGHT FRONT OF THE ENG TAKE THE HOSE LOOSE AT THE FILTER HOLD IT UP AND FILL IT WITH HYD FLUID PUT THE HOSE BACK ON AND START DOZER IMED OK
