gatractorman - ? on Bobcat 753 creep
New Owner Bobca
03-29-2004 11:38:55
Hi,
I just took ownership of a 1995 753 and am noticing that when stopped, it will slowly creep. Sometimes from left to right, sometimes from right to left. Someone told me that it had to do with tire pressures, could that be true?
Roy
03-29-2004 19:54:40
 Re: gatractorman - ? on Bobcat 753 creep in reply to New Owner Bobcat 753, 03-29-2004 11:38:55
Just worked on a 642-b bob-kitty.Found that there are round contactpoints on the pump levers. where these rounds contact the flat bar you will find worn spots on the flats and on the round pieces . I was told these surfaces need to be flat and concentric. Replace as necessary. Jack up the machine put it on wood blocks so tires clear the ground. At idle or low rpm loosen the 2 bolts on the flat bar and move it tighter to the lever assy.
Watch out for turning tires... I found if you work with it for a while you can get most of the creep out.. Or at least enough that the brake will hold it in place while parked
New Owner
03-30-2004 05:49:18
 Re: Re: gatractorman - ? on Bobcat 753 creep in reply to Roy, 03-29-2004 19:54:40
Thanks!
