Another question...Lavoy?
Bernie in MA
03-29-2004 15:49:01
My 420C steering clutch was slipping. It was the pressure plate so I put in a used one. Then it wouldn't release, so now that my new knee is healed I pulled it apart again to put in a new pressure plate. I found the used pp was not adjusted incorrectly; the fingers measure the same as the new one. The only thing I can think of is the gear the discs slip onto is rusty, not letting them separate easily. I've cleaned the gear up, should it have a little grease applied?
Jonathan in MA
03-29-2004 19:18:04
 Re: Another question...Lavoy? in reply to Bernie in MA, 03-29-2004 15:49:01
Not sure how the 420 clutch assembly is stacked, but if its similar to a 350, a fiber disc is installed first, then the center hub with a large snap ring installed on it, then a steel plate and alternate fiber and steel. I've seen several instances where people installed the center hub(gear) with that snap ring on it, and THEN start the stacking procedure. This piles everything above that snap ring and makes it act like it has an extra disc installed and won't release. I may be totally wrong as I don't have a 420 parts book, but just an idea...
Bernie in MA
03-30-2004 06:30:26
 Re: Re: Another question...Lavoy? in reply to Jonathan in MA, 03-29-2004 19:18:04
The 420 is different; the hub stays on and the discs are stacked over it. That's the way the book says and that's the way I've always done it. The discs were separating before with the rust on the hub. I can't figure out why they're hanging up now. Thanks for your reply.
