Won't Start, Electrical ugh
RexB
04-02-2004 16:39:33
Was clearing -pushing over trees, grading, skidding- and saw that my temperature, charging and oil pressure gauges had bottomed out to 'zero' no reading. They had been reading normal all day. So i shut the diesel off, sat 5 minutes then tried to start it, nothing at all. Per service manual, all wiring is tight and correct on the key ignition, starter, solenoid, and alternator. There is no breaker/fuse. 1/2 tank of fuel, valve is on. The new battery reads 12.9v output. Just no life in the gauges, starter won't turn.
A bad key ignition is my best guess- how can i wire around it till i order a new one? Or anybody give me an idea on the cause of problem?
JD350
04-03-2004 06:51:16
 Re: Won't Start, Electrical ugh in reply to RexB, 04-02-2004 16:39:33
It's a JD350, year 1966.
Fixed It
04-03-2004 12:05:10
 Re: Re: Won't Start, Electrical ugh in reply to JD350, 04-03-2004 06:51:16
Fixed. No continuity thru harness, crawled underneath, limb wedged into undercarriage had ripped out the cabling, replaced, works like a champ again.
RexB
