question 350C (Jdemaris?)
Mark
04-07-2004 08:40:53
Found a winch, model 3315, $1850. Does this sound like the correct series of #'s for the 350's? I need to fine out if I have a spline behind that little cover on the back of the trans housing. If I remove it, will hyd. fluid pour out? If so, what if I parked down hill pretty steep to take a peek? thanks, Mark
jdemaris
04-07-2004 20:06:35
 Re: question 350C (Jdemaris?) in reply to Mark, 04-07-2004 08:40:53
3315 sounds like one of the winches that was used. I think parking down hill is a good idea. Sometimes, all you're going to have is a splined collar hooked to a powershaft inside the back of the transmission. You'll need the outer shaft and carrier.
