Reversor Pump Housing
Wingnut
04-09-2004 06:05:16
JDE..?Did have to cut lining on torsional plate..It was to thick and set to far out from flywheel which caused it to rub up against bolts on reversor pump housing..plus it sat to far out on the flywheel pin.....So right now its just a hair over a 1/8 inch thick...Now that i look at it is the pump mounted correct ?? or should it be turned over??...Once again i wasnt paying attention...and by the time i decided to take a pic i had already took it off and set it aside...thanks
Hers the link
www.safewerks.com/PICT1622.JPG Wing
jdemaris
04-09-2004 06:58:49
 Re: Reversor Pump Housing in reply to Wingnut, 04-09-2004 06:05:16
I could be wrong, but as I recall that cover cannot be put in upside down - the dowels and bolts only line up one way. But, it's been 15 years since I looked at one.
